  • YAF Leader Topic Starter YAF Version: YAF 3.1.16
Are there any details on upgrading the DNN YAF module?
I see this in the readme, but it doesn't say what file, other than Default.aspx?
Open the file YourWebsite.com/DesktopModules/YetAnotherForumDotNet/install/ on your web site.
Should you run the install extension wizard via DNN?
Should you unpack the files an overwrite then hit Default.aspx?
I think I'm missing something obvious with this upgrade.
I'm running DNN 6.0 if that matters.
I tried doing as the ReadMe file states, and it didn't update anything. I then copied all the files and when I attempted to open a thread topic, I received the message below.
A critical error has occurred.Value was either too large or too small for an Int16.
I reverted to the backup database and have
DotNetNuke: 06.00.01 (310)
YetAnotherForum: 1.95.54750
... functioning once again.
I just need help with the proper step by step process for installing please.
Yes you need to run the Dnn Install Extension wizzard to Update the Module, the Yaf Upgrade Wizzard should Open and needs to be executed when you visit the forum Page.
If the error still appears, please post the full error from the Event Log.
After confirming/accepting the license agreement screen. The upgrade timed out.
 Request timed out.
Exception Details: System.Web.HttpException: Request timed out.
[HttpException (0x80004005): Request timed out.]
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
Here's what the Event Log stated regarding the timeout.
AssemblyVersion: 6.0.1
PortalID: 0
PortalName: PackersHome
UserID: 4
UserName: Zero2Cool
ActiveTabID: 41
ActiveTabName: Home
RawURL: /
AbsoluteURL: /default.aspx
AbsoluteURLReferrer: http://packershome.com/DesktopModules/YetAnotherForumDotNet/install/default.aspx?upgrade=46
UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:6.0.1) Gecko/20100101 Firefox/6.0.1
DefaultDataProvider: DotNetNuke.Data.SqlDataProvider, DotNetNuke.SqlDataProvider
ExceptionGUID: 8db71e21-126b-4a29-87fa-c4cbec1e3e40
InnerException: Could not load type 'DotNetNuke.Modules.Chat.Components.DNNChatController'.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Web.Compilation.BuildManager.GetType
StackTrace:
Message: System.Web.HttpException (0x80004005): Could not load type 'DotNetNuke.Modules.Chat.Components.DNNChatController'. at System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) at DotNetNuke.Framework.Reflection.CreateType(String TypeName, String CacheKey, Boolean UseCache, Boolean IgnoreErrors)
and when I open a topic/thread, this is the message in the EventLog
PortalID: 0
UserID: 4
UserName: Zero2Cool
ActiveTabID: 63
ActiveTabName: Forum
RawURL: /tabid/63/g/posts/t/13605/Is-Tramon-Williams-a-pussy.aspx
AbsoluteURL: /Default.aspx
AbsoluteURLReferrer: http://packershome.com/tabid/63/g/topics/f/4/Let-s-Talk-Green-Bay-Packers.aspx
ExceptionGUID: 7f160b02-f1b1-499a-9a89-c760cce75352
InnerException: Value was either too large or too small for an Int16.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Int16.Parse
StackTrace:
Message: DotNetNuke.Services.Exceptions.PageLoadException: Value was either too large or too small for an Int16. ---> System.OverflowException: Value was either too large or too small for an Int16. at System.Int16.Parse(String s, NumberStyles style, NumberFormatInfo info) at System.String.System.IConvertible.ToInt16(IFormatProvider provider) at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider) at System.Convert.ChangeType(Object value, Type conversionType) at YAF.Classes.Pattern.RegistryDictionary.GetValue[T](String name, T defaultValue) at YAF.Classes.Pattern.RegistryDictionaryOverride.GetValue[T](String name, T defaultValue, Boolean allowOverride) at YAF.Classes.Pattern.RegistryDictionaryOverride.GetValue[T](String name, T defaultValue) at YAF.Classes.YafBoardSettings.get_MaxPostSize() at YAF.Controls.MessagePostData.TruncateMessage(String message) at YAF.Controls.MessagePostData.get_Message() at YAF.Controls.MessagePostData.RenderMessage(HtmlTextWriter writer) at YAF.Controls.MessagePost.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at YAF.Core.ForumPage.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at YAF.Forum.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at DotNetNuke.UI.Modules.ModuleHost.RenderContents(HtmlTextWriter writer) at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.portals__default_containers_sf001_forestgreen_barframe_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.portals__default_skins_packershomedark_h_bordered_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Control.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at ASP.default_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at DotNetNuke.Framework.PageBase.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
Source:
Server Name:
To Resolve the Timeout Issue you need to Increase the Timeout Value in your web.config, because the Installer is very Big
<httpRuntime useFullyQualifiedRedirectUrl="true" maxRequestLength="28192" executionTimeout="6000" requestLengthDiskThreshold="18192" />
Looks Like there is a Problem with The Max Post Size Value, did you changed that Value in the Host Settings?
Try to set it to the Default Value 32767
Yes sir, I did increase it. Doing the upgrade busted up the site, working on getting it back up again. I'll report back if changing that works, as well as the timeout suggestion. Thank you.
Those two suggestions worked. There's a few "quirks" I noticed right away, I'll make new threads unless I find it's my own fault. 🙂
Dr-Hack
  • Dr-Hack
  • YAF All-the-Time
ok i did the same ..
in which table will i find this so i can change it into the default value .. saw all the tables starting with yaf .. couldnt find it .. missed it ?
thanks..
EDIT: Just ran the install again .. got it fixed .. by if we end up in trouble what is the actual way to tackle it ? and why not to have form restriction if increasing the value makes it break ?
EDIT 2: OOH no .. the forum is working cant go into host settings .. so cant change it back..i guess back to my question in the post..
Dr-Hack
  • Dr-Hack
  • YAF All-the-Time
still getting the error . .cant open Host settings :S .. which table which table ? :S ...
getting :
 A critical error has occurred. Exception has been thrown by the target of an invocation.
waiting .
Its in the Table "yaf_Registry"
This issue is fixed in 1.96 RC 1
Dr-Hack
  • Dr-Hack
  • YAF All-the-Time
thanks alot man.
was sitting idle and refreshing this post again and again and again .. for like three hours ..
ouch
"be careful "
Got your PM on my board, but you deleted your account or something? Hope you got your problem resolved.
Dr-Hack
  • Dr-Hack
  • YAF All-the-Time
Originally Posted by: Zero2Cool
yeah fixed 🙂 ... didnt unregisster the reversechars not working , maybe someone fixed it on PS :)
