panron
  • panron
  • 52.6% (Neutral)
  • YAF Forumling Topic Starter YAF Version: 2.3.1.15
a month ago
I am having issues upgrading to the latest version. I started with version 2.2 and tried to upgrade directly to the 3.2.7 but it did not work, there were messages about multiple missing columns when trying to start the site.
I was able to upgrade to 2.3.1.15 without issues.
I tried upgrading to different point releases of v3, the lowest being 3.0.2 but even that gives the error message when starting the site:
Exception type: SqlException
    Exception message: Invalid column name 'PageSize'.
I seem to have an issue with the membership migration going from v2 to v3?
Also, the main reason (other than old age) for updating is that emails are no longer being sent from the forum even though nothing has changed. This email issue also persist s with 2.3.1.15 version. There is an error in the log "System.Net.Mail.SmtpException: The operation has timed out.". I am able to send mail from other services using the same smtp server settings.
a month ago
You should be able to upgrade from any version directly to the latest version.
I tested upgrading from 2.3.1.15 to 3.2.7. and it worked without issues.
You wrote that you initially tried to upgrade from 2.2 to 3.2.7 and then to version 2.3.1.15 did you every time restored the db, before upgrading?  If you try to upgrade to different version its possible the the upgrade migration was not working correctly.
panron
  • panron
  • 52.6% (Neutral)
a month ago
Yes, I restored the db and I just retested again to be sure. Still the same error about the missing PageSize column (tried 3.0.2) when starting.
However, now I went to the "forum/install"-page manually and was able to run the upgrade process. The database looks to have updated, but now I have a null value error instead when navigating to the forum.
​Exception information:
    Exception type: ArgumentNullException
    Exception message: Value cannot be null.
Parameter name: value
   at System.Runtime.Caching.MemoryCacheEntry..ctor(String key, Object value, DateTimeOffset absExp, TimeSpan slidingExp, CacheItemPriority priority, Collection`1 dependencies, CacheEntryRemovedCallback removedCallback, MemoryCache cache)
   at System.Runtime.Caching.MemoryCache.Set(String key, Object value, CacheItemPolicy policy, String regionName)
   at System.Runtime.Caching.MemoryCache.set_Item(String key, Object value)
   at YAF.Core.Configuration.Pattern.TypeFactoryInstanceApplicationScope`1.Get()
   at YAF.Core.Services.LinkBuilder.GetLink(ForumPages page, Boolean fullUrl)
   at YAF.Core.Services.LinkBuilder.Redirect(ForumPages page)
   at YAF.Core.Services.Permissions.HandleRequest(ViewPermissions permission)
   at YAF.Modules.PageSecurityForumModule.PagePreLoad_HandleEvent(Object sender, EventConverterArgs`1 e)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at System.Collections.Generic.List`1.ForEach(Action`1 action)
   at System.Web.UI.Control.OnInit(EventArgs e)
   at System.Web.UI.Control.InitRecursive(Control namingContainer)
   at System.Web.UI.Control.AddedControl(Control control, Int32 index)
   at YAF.Web.Controls.Forum.OnLoad(EventArgs e)
   at System.Web.UI.Control.LoadRecursive()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
a month ago
But why did you try now with 3.0.2?
panron
  • panron
  • 52.6% (Neutral)
a month ago
That configuration I had already setup so it was the easiest (and I thought it would have the least changes for the transition from v2 to v3).
I also noticed that I am limited to 3.1.15 because I am on Windows Server 2019 which does not support .net 4.8.1 (unless I go v4, but that is not fully released yet).
a month ago
Originally Posted by: panron
Okay, that’s understandable. But there where some isssues in the first releases of 3.x regarding updating.
But I don’t think upgrading to the latest version will resolve the mail issue for you.
does it not send any emails? If so then have you enabled ssl for the mail settings?
panron
  • panron
  • 52.6% (Neutral)
a month ago
Yes, I have SSL enabled. It was working for a long time until it just stopped. I suspected there might be some library or protocol version issues because of the old version I was using so I started to update. It could also be some server issue, although other services are sending mail just fine.
a month ago
I asked about ssl because before version 3, it had to be enabled via the appSettings in version 3 it’s set via the mailSettings section of the web.config. Other then that you should check if the port is correct.
